Because asynchronous motors have the characteristics of high stage, nonlinear, strong coupling and various variables, the actual control of the asynchronous motor is very difficult. Vector control is mainly used to settle this problem with the theme of that divide the stator current vector into exciting current (the current heft generating internal magnetic field of the motor) and torque current (the current heft generating torque) by controlling and measuring the stator current vector according to the principles of beamed magnetic field to control the range and phase of these two hefts. This method can realize the decoupling of exciting current and torque current to adjust the high performance of asynchronous motors.
Goodrive35 series VFDs are embedded speedless sensor vector control calculation for driving both asynchronous motors and synchronous motors. Because the core calculation of vector control is based on exact motor parameter models, the accuracy of motor parameter will impact on the performance of vector control. It is recommended to input the motor parameters and carry out autotune before vector running.
Because the vector control calculation is very complicated, high technical theory is needed for the user during internal autotune. It is recommended to use the specific function parameters in vector control with cautions.
Function code
Default value
P00.00
Speed control mode
0: Sensorless vector control mode 1
1: Sensorless vector control mode 2
2: SVPWM   control
3: Closed-loop   vector control mode
P00.15
Motor parameter   autotuning
0: No operation
1: Rotation   autotuning
2: Static autotuning   1 (autotune totally)
3: Static   autotuning 2 (autotune part parameters)
P02.00
Motor type 1
0: Asynchronous   motor
1: Synchronous   motor
P03.00
ASR proportional   gain1
0–200.0
16.0
P03.01
ASR integral time1
0.000–10.000   s
0.200 s
P03.02
Low-point frequency for switching
0.00 Hz–P03.05
5.00 Hz
P03.03
ASR proportional   gain 2
0–200.0
10.0
P03.04
ASR integral time 2
0.000–10.000   s
0.200 s
P03.05
High-point frequency for switching
P03.02–P00.03   (max. output frequency)
10.00 Hz
P03.06
ASR output filter
0–8 (corresponds   to 0–28/10 ms)
P03.07
Compensation coefficient   of electromotion slip
50%–200%
100%
P03.08
Compensation   coefficient of brake slip
50%–200%
100%
P03.09
ACR proportional   coefficient P
0–20000
1000
P03.10
ACR integral   coefficient I
0–20000
1000
P03.11
Torque setting   method
0: Torque control is   invalid
1: Keypad setting   torque (P03.12)
2: Analog AI1   setting torque
3: Analog AI2   setting torque
4: Analog AI3   setting torque
5: Pulse frequency   HDI setting torque
6: Multi-step torque   setting
7: Modbus   communication setting torque
8: PROFIBUS/CANopen   communication setting torque (the same as above)
9: Ethernet   communication setting torque  (the same   as above)
10: Reserved
Note: Setting   modes 2–10, 100% corresponds to three times of the rated current of the   motor.
P03.12
-300.0%–300.0%   (rated motor current)
10.0%
P03.13
Torque reference   filter time
0.000–10.000s
0.100   s
P03.14
Upper frequency of   forward rotation in vector control
0: Keypad   (P03.16)
1: AI1
2: AI2
3: AI3
4: Pulse   frequency HDI setting upper-limit frequency
5: Multi-step   setting upper-limit frequency
6: Modbus   communication setting upper-limit frequency
7:   PROFIBUS/CANopen communication setting upper-limit frequency
8: Ethernet   communication setting upper-limit frequency (the same as above)
Note: Setting method   0–8, 100% corresponds to the maximum frequency.
P03.15
Upper frequency of   reverse rotation in vector control
0: Keypad (P03.17)
1–8: The   same as P03.14
P03.16
Keypad setting for   upper frequency of forward rotation
Setting   range: 0.00 Hz–P00.03 (max. output frequency)
50.00 Hz
P03.17
Keypad setting for   upper frequency of reverse rotation
50.00 Hz
P03.18
Upper electromotion   torque source
0: Keypad   setting upper-limit frequency (P03.20)
1: AI1
2: AI2
3: AI3
4: HDI
5: Modbus   communication
6:   PROFIBUS/CANopen communication
7: Ethernet communication
Note: Set mode   1–7, 100% corresponds to three times of the motor current.
P03.19
Upper brake torque   source
0: Keypad   (P03.21)
1–7: The same as P03.18
P03.20
Keypad setting of   electromotion torque
0.0–300.0%   (rated current of the motor)
180.0%
P03.21
Keypad setting of brake   torque
180.0%
P03.22
Weakening   coefficient in constant power zone
0.01–2.00
1.00
P03.23
Lowest weakening   point in constant power zone
5%–50%
10%
P03.24
Max voltage limit
0.0–120.0%
100.0%
P03.25
Pre-exciting time
0.000–10.000   s
0.0 s
P03.26
Weak proportional   gain
0–8000
1200
P03.27
Integral gain of the   flux weakening
0–8000
1200
P03.28
Control mode of the flux   weakening
0x000–0x112
Ones: Control mode selection
0–2
Tens: Inductance compensation selection
0: Compensate
1: Not compensate
Hundreds: High speed control mode
0: Mode 0
1: Mode 1
0x000
P03.29
Torque control mode
0x0000–0x7111
Ones: Torque command selection
0: Torque reference
1: Torque current reference
Tens: Torque compensation direction at 0 speed
0: Positive
1: Negative
Hundreds: ASR integral separation   setting
0: Disabled
1: Enabled
Thousands: Torque control   word setting
Bit0: Torque command   filtering mode
0: Inertia filter
1: Linear ACC/DEC filtering
Bit1–2: ACC/DEC time for   rotating speed upper limit
0: No ACC/DEC time
1: ACC/DEC time 1
2: ACC/DEC time 2
3: ACC/DEC time 3
0x0001
P03.30
Low-speed friction   torque
0–50.0%   (rated torque of the motor)
0.0%
P03.31
High-speed friction   torque
0.0%
P03.32
Corresponding   frequency of high-speed friction torque
1.00 Hz–400.00   Hz
50.00 Hz
