Physical accident may occur if the motor starts up   suddenly during autotune. Please check the safety of surrounding environment   of the motor and the load before autotune.
The power is still applied even the motor stops   running during static autotune. Please do not touch the motor until the   autotune is completed, otherwise there would be electric shock.
Do not carry out the rotation autotune if the   motor is coupled with the load, please do not operate on the rotation   autotune. Otherwise misacts or damage may occur to the VFD or the mechanical   devices. When carry out autotune on the motor which is coupled with load, the   motor parameter won’t be counted correctly and misacts may occur. It is   proper to de-couple the motor from the load during autotune when necessary.
Goodrive35 series VFDs can drive both asynchronous motors and synchronous motors. And at the same time, they can support two sets of motor parameters which can shift between two motors through multi-function digital input terminal or communication.
The control performance of the VFD is based on the established accurate motor model. The user has to carry out the motor autotuning before initial running (take motor 1 as an example).
1. Set the motor parameters according to the name plate of the motor.
2. During the motor autotune, de-couple the motor form the load if rotation autotune is selected to make the motor is in a static and empty state, otherwise the result of autotune is incorrect. The asynchronous motors can autotune the parameters of P02.06–P02.10, while the synchronous motors can autotune the parameters of P02.20–P02.23.
3. During the motor autotune, do not to de-couple the motor form the load if static autotune is selected. Because only some parameters of the motor are involved, the control performance is not as better as the rotation autotune. The asynchronous motors can autotune the parameters of P02.06–P02.10, while the synchronous motors can autotune the parameters of P02.20–P02.22. P02.23 (synchronous motor 1 counter-electromotive force constant) can be counted to attain.
4. Motor autotune only involves the current motor. Switch the motor through P08.31 to carry out the autotune on the other motor.
Relative parameters list:
Function    code
Default    value
P00.01
Run command channel
0: Keypad   running command (LED off)
1: Terminal   running command channel (LED flickering)
2: Communication   running command channel (LED on)
P00.15
Motor parameter autotuning
0: No operation
1: Rotation autotuning
2: Static autotuning 1 (autotune totally)
3: Static autotuning 2 (autotune part   parameters)
P02.00
Motor 1
0: Asynchronous motor
1: Synchronous   motor
P02.01
Rated power of asynchronous motor 1
0.1–3000.0 kW
Depend on model
P02.02
Rated frequency of asynchronous motor 1
0.01 Hz–P00.03 (max. output frequency)
50.00 Hz
P02.03
Rated speed of asynchronous motor 1
1–36000rpm
Depend on model
P02.04
Rated voltage of asynchronous motor 1
0–1200 V
Depend on model
P02.05
Rated current of asynchronous motor 1
0.8–6000.0A
Depend on model
P02.06
Stator resistor of asynchronous motor 1
0.001–65.535Ω
Depend on model
P02.07
Rotor resistor of asynchronous motor 1
0.001–65.535Ω
Depend on model
P02.08
Leakage inductance of asynchronous motor 1
0.1–6553.5 mH
Depend on model
P02.09
Mutual inductance of asynchronous motor 1
0.1–6553.5 mH
Depend on model
P02.10
Non-load current of asynchronous motor 1
0.1–6553.5 A
Depend on model
P02.15
Rated power of synchronous motor 1
0.1–3000.0 kW
Depend on model
P02.16
Rated frequency of synchronous motor 1
50.00 Hz
P02.17
Number of poles pairs for synchronous motor   1
1–128
P02.18
Rated voltage of synchronous motor 1
0–1200 V
Depend on model
P02.19
Rated current of synchronous motor 1
0.8–6000.0 A
Depend on model
P02.20
Stator resistor of synchronous motor 1
0.001–65.535 Ω
Depend on model
P02.21
Direct axis inductance of synchronous motor   1
0.01–655.35 mH
Depend on model
P02.22
Quadrature axis inductance of synchronous   motor 1
0.01–655.35 mH
Depend on model
P02.23
Back EMF constant of synchronous motor 1
0–10000
300
P05.01–P05.09
Multi-function digital input terminals
 (S1–S8,   HDI) function selection
35: Shift   from motor 1 to motor 2
P08.31
Motor shifting
0: Terminal shifting;
1: Modbus communication shifting
2: PROFIBUS/CANopen communication shifting
P12.00
Motor 2
P12.01
Rated power of asynchronous motor 2
0.1–3000.0 kW
Depend on model
P12.02
Rated frequency of asynchronous motor 2
50.00 Hz
P12.03
Rated speed of asynchronous motor 2
1–36000 rpm
Depend on model
P12.04
Rated voltage of asynchronous motor 2
0–1200 V
Depend on model
P12.05
Rated current of asynchronous motor 2
0.8–6000.0 A
Depend on model
P12.06
Stator resistor of asynchronous motor 2
0.001–65.535 Ω
Depend on model
P12.07
Rotor resistor of asynchronous motor 2
0.001–65.535 Ω
Depend on model
P12.08
Leakage inductance of asynchronous motor 2
0.1–6553.5 mH
Depend on model
P12.09
Mutual inductance of asynchronous motor 2
0.1–6553.5 mH
Depend on model
P12.10
Non-load current of asynchronous motor 2
0.1–6553.5 A
Depend on model
P12.15
Rated power of synchronous motor 2
0.1–3000.0 kW
Depend on model
P12.16
Rated frequency of synchronous motor 2
50.00 Hz
P12.17
Number of poles pairs for synchronous motor   2
1–128
P12.18
Rated voltage of synchronous motor 2
0–1200 V
Depend on model
P12.19
Rated current of synchronous motor 2
0.8–6000.0 A
Depend on model
P12.20
Stator resistor of synchronous motor 2
0.001–65.535 Ω
Depend on model
P12.21
Direct axis inductance of synchronous motor   2
0.01–655.35 mH
Depend on model
P12.22
Quadrature axis inductance of synchronous   motor 2
0.01–655.35 mH
Depend on model
P12.23
Back EMF constant of synchronous motor 2
0–10000
300
