The start-up and stop control of the VFD includes three states: start after the running command during normal powering on, start after the restarting function becomes valid during normal powering on and start after the automatic fault reset.
There are three starting modes for the VFD: start from the starting frequency directly, start after the AC brake and start after the rotation speed tracking. The user can select according to different situations to meet their needs.
For the load with big inertia, especially in the cases where the reverse rotation may occur, it is better to select starting after DC brake and then starting after rotation speed tracking.
Note: It is recommended to use the direct starting to drive synchronous motor.
1. The starting logic figure of starting after the running command during the normal powering on.
2. The starting logic figure of starting after the restarting function becomes valid during the normal powering on.
3. The starting logic figure of starting after the automatic fault reset.
Relative parameters list:
Function    code
Default    value
P00.01
Run command channel
0: Keypad running command (LED off)
1: Terminal running command channel (LED   flickering)
2: Communication running command channel (LED   on)
P00.11
ACC time 1
0.0–3600.0   s
Depend on model
P00.12
DEC time 1
0.0–3600.0   s
Depend on model
P01.00
Start mode
0: Start-up   directly
1: Start-up   after DC brake
2: Start-up after rotation speed tracking
P01.01
Starting frequency of direct start
0.00–50.00   Hz
0.00 Hz
P01.02
Retention time of the starting frequency
0.0–50.00   s
0.00s
P01.03
The brake current before starting
0.0–100.0%
0.0%
P01.04
The brake time before starting
0.0–30.0 s
0.0s
P01.05
ACC/DEC selection
0: Linear type
1: S   curve
P01.06
ACC time of the starting step of S curve
0.0–50.0s
0.1s
P01.07
DEC time of the ending step of S curve
0.0–50.0s
0.1s
P01.08
Stop mode
0: Decelerate   to stop
1: Coast   to stop
P01.09
Starting frequency of DC brake
0.00 Hz–P00.03   (max. output frequency)
0.00 Hz
P01.10
Waiting time of DC brake
0.00–30.00   s
0.00s
P01.11
DC brake current
0.0–100.0%
0.0%
P01.12
DC brake time
0.0–50.0 s
0.0 s
P01.13
Dead time of FWD/REV rotation
0.0–3600.0   s
0.0 s
P01.14
Shifting between FWD/REV rotation
0: Switch   after zero frequency
1: Switch   after the starting frequency
P01.15
Stopping speed
0.00–100.00 Hz
0.20 Hz
P01.16
Detection of stopping speed
0: Speed   setting (the only detection method in SVPWM mode)
1: Speed detecting value
P01.18
Terminal
running protection when powering on
0: The terminal running command is invalid   when powering on
1: The terminal running command is valid   when powering on
P01.19
Action if running frequency< lower limit   frequency (valid >0)
0:   Run at the lower-limit frequency
1:   Stop
2:   Hibernation
3: Run at zero frequency
P01.20
Hibernation restore delay time
0.0–3600.0s (valid when P01.19=2)
0.0s
P01.21
Restart after power off
0: Disable
1: Enable
P01.22
The waiting time of restart after power off
0.0–3600.0 s (valid when P01.21=1)
1.0s
P01.23
Start delay time
0.00–60.00 s
0.00s
P01.24
Delay time of the stopping speed
0.00–60.00   s
0.00s
P05.01–P05.09
Digital input function selection
1: Forward   rotation operation
2: Reverse rotation operation
4: Forward   rotation jogging
5: Reverse   rotation jogging
6: Coast   to stop
7: Fault   reset
8: Operation pause
21: ACC/DEC   time option 1
22: ACC/DEC   time option 2
30: ACC/DEC prohibition
P08.00
ACC time 2
0.0–3600.0   s
Depend on model
P08.01
DEC time 2
0.0–3600.0   s
Depend on model
P08.02
ACC time 3
0.0–3600.0   s
Depend on model
P08.03
DEC time 3
0.0–3600.0   s
Depend on model
P08.04
ACC time 4
0.0–3600.0   s
Depend on model
P08.05
DEC time 4
0.0–3600.0   s
Depend on model
P08.06
Jogging frequency
0.00–P00.03 (max. output frequency)
5.00 Hz
P08.07
Jogging ACC time
0.0–3600.0 s
Depend on model
P08.08
Jogging DEC time
0.0–3600.0 s
Depend on model
P08.28
Fault reset times
0–10
P08.29
Interval time of automatic fault reset
0.1–3200.0 s
1.0 s
