Goodrive35 series VFDs have three analog input terminals and 1 high-speed pulse input terminals (of which, AI1 and AI2 are 0–10 V/0–20mA and Al can select voltage input or current input by J3, AI2 can select voltage input or current input by J4 and AI3 is for -10–10 V) as the standard configuration. The inputs can be filtered and the maximum and minimum values can be adjusted.
Relative parameters list:
Function    code
Default    value
P05.00
HDI input selection
0: High   pulse input
1: Digital input.
P05.32
Lower limit of AI1
0.00 V–P05.34
0.00 V
P05.33
Corresponding setting of lower limit of AI1
-300.0%–300.0%
0.0%
P05.34
Upper limit of AI1
P05.23–10.00 V
10.00 V
P05.35
Corresponding setting of upper limit of AI1
-300.0%–300.0%
100.0%
P05.36
AI1 input filter time
0.000s–10.000s
0.030 s
P05.37
Lower limit of AI2
0.00 V–P05.39
0.00 V
P05.38
Corresponding setting of lower limit of AI2
-300.0%–300.0%
0.0%
P05.39
Upper limit of AI2
P05.37–10.00 V
10.00 V
P05.40
Corresponding setting of upper limit of AI2
-300.0%–300.0%
100.0%
P05.41
AI2 input filter time
0.000s–10.000 s
0.030 s
P05.42
Lower limit of AI3
-10.00 V–P05.44
-10.00 V
P05.43
Corresponding setting of lower limit of AI3
-300.0%–300.0%
-100.0%
P05.44
Zero-drift value of AI3
P05.42–P05.46
0.00 V
P05.45
Zero-point deadzone voltage of AI3
0.00–10.00 V
0.04 V
P05.46
Upper limit of AI3
P05.44–10.00 V
10.00 V
P05.47
Corresponding setting of upper limit of AI3
-300.0%–300.0%
100.0%
P05.48
AI3 input filter time
0.000s–10.000 s
0.030 s
P05.49
HDI high-speed pulse input function
0: Frequency   setting input
1–2:   Reserved
P05.50
Lower limit frequency of HDI
0.00 kHz – P05.43
0.000 kHz
P05.51
Corresponding setting of HDI low frequency   setting
-300.0%–300.0%
0.0%
P05.52
Upper limit frequency of HDI
P05.41–50.00 kHz
50.000   kHz
P05.53
Corresponding setting of upper limit   frequency of HDI
-300.0%–300.0%
100.0%
P05.54
HDI frequency input filter time
0.000s–10.000 s
0.030 s
