Traverse is applied in some industries such as textile, chemical fiber and cases where traverse and convolution is required. The working flowchart is as below:
Function    code
Default    value
P00.03
Max. output frequency
P00.03–400.00Hz
50.00Hz
P00.06
A frequency command
0: Keypad
1: AI1
2: AI2
3: AI3
4:High-speed   pulse HDI
5:Simple   PLC program
6: Multi-step speed running
7: PID control setting
8: Modbus   communication setting
9: PROFIBUS/CANopen   communication setting
10: Ethernet   communication setting(reserved)
11: Reserved
P00.11
ACC time 1
0.0–3600.0s
Depend on model
P00.12
DEC time 1
0.0–3600.0s
Depend on model
P05.01–P05.09
Digital input function selection
26:Traverse Pause (stop at the current   frequency)
27:Traverse   reset (return to the center frequency)
P08.15
Traverse range
0.0–100.0% (corresponding   to the set frequency)
0.0%
P08.16
Sudden jumping frequency range
0.0–50.0%   (corresponding to the traverse range)
0.0%
P08.17
Traverse boost time
0.1–3600.0s
5.0s
P08.18
Traverse declining time
0.1–3600.0s
5.0s
