Goodrive300 series VFDs support fixed-length control function which can input length counting pulse through HDI, and then count the actual length according to the internal counting formula. If the actual length is longer than or equal to the set length, the digital output terminal can output the length arrival pulse signal of 200ms and the corresponding length will clear automatically.
Note: The parameter of "Length arrival" is related to pulse output and the lasting time is 200ms.
Function    code
Default    value
P05.00
HDI input selection
0: High pulse input.
1: Digital input.
P05.49
HDI high-speed pulse input function
selection
0: Frequency setting input
1: Counter input
2: Length   counting input
P05.01– P05.09
Digital input   function selection
32: Length reset
P06.01– P06.04
Digital output   function selection
21: Length arrival
P08.19
Set length
0–65535m
P08.20
Actual length
0–65535m
P08.21
Pulse per rotation
1–10000
P08.22
Alxe perimeter
0.01–100.00cm
10.00
P08.23
Length ratio
0.001–10.000
1.000
P08.24
Length correcting coefficient
0.001–1.000
1.000
P17.17
Length
0–65535
P17.22
HDI input frequency
Display HDI input   frequency
Range: 0.00–50.00kHz
0.00kHz
