Function    code
Default    value
Modify
P06.00
HDO output
The function selection of the high-speed pulse   output terminals.
0: Open collector high speed pulse output:   The Max.pulse frequency is 50.0kHz. See P06.27–P06.31 for detailed   information of the related functions.
1: Open collector output. See P06.02 for   detailed information of the related functions.
P06.01
Y1 output
0: Invalid
1: In operation
2: Forward rotation operation
3: Reverse rotation operation
4: Jogging operation
5: The VFD fault
6: Frequency degree test FDT1
7: Frequency degree test FDT2
8: Frequency arrival
9: Zero speed running
10: Upper limit frequency arrival
11: Lower limit frequency arrival
12: Ready for operation
13: Pre-magnetizing
14: Overload pre-alarm
15: Underload pre-alarm
16: Completion of simple PLC stage
17: Completion of simple PLC cycle
18: Set count value reached
19: Specified count value reached
20: External fault valid
21: Length arrival
22: Running time arrival
23: Modbus communication virtual terminals output
24: PROFIBUS/CANopen communication virtual   terminals output
25: Ethernet communication virtual   terminals output
26: Voltage establishment finished
27–30: Reserved
P06.02
HDO output
P06.03
Relay RO1 output
P06.04
Relay RO2 output
5
P06.05
Polarity of output terminals
The function code is used to set the pole of the   output terminal.
When the current bit is set to 0, the input   terminal is anode.
When the current bit is set to 1, the input   terminal is cathode.
Setting   range: 00–0F
00
P06.06
Y1 switch-on delay time
The function code defines the corresponding delay   time of the electrical level change during the programmable terminal   switching on and off.
Setting range: 0.000–50.000s
Note: P06.08   and P06.08 are valid only when P06.00=1.
0.000s
P06.07
Y1 switch-off delay time
0.000s
P06.08
HDO switch-on delay time
0.000s
P06.09
HDO switch-off delay time
0.000s
P06.10
RO1 switch-on delay time
0.000s
P06.11
RO1 switch-off delay time
0.000s
P06.12
RO2 switch-on delay time
0.000s
P06.13
RO2 switch-off delay time
0.000s
P06.14
AO1 output
0: Running frequency
1: Set frequency
2: Ramp reference frequency
3: Running rotation speed (relative to 2   times the synchronous rotation speed of the motor)
4: Output current (relative to 2 times the   rated current of the VFD)
5: Output current (relative to 2 times the   rated current of the motor)
6: Output voltage (relative to 1.5 times   the rated voltage of the VFD)
7: Output power  (relative to 2 times the rated power of the   motor)
8: Set torque value (relative to 2 times   the rated torque of the motor)
9: Output torque (relative to 2 times the   rated torque of the motor)
10: Analog AI1 input   value
11: Analog AI2 input   value
12: Analog AI3 input   value
13: Input value   of high-speed pulse HDI
14: Modbus communication set value 1
15: Modbus communication set value 2
16: Set value 1 of PROFIBUS/CANopen   communication
17: Set value 2 of PROFIBUS/CANopen   communication
18: Set value 1 of Ethernet communication
19: Set value 2 of Ethernet communication
20–21: Reserved
22: Torque current (corresponding to triple   the rated current of the motor)
23: Ramp reference frequency (with sign)
24–30: Reserved
P06.15
AO2 output
P06.16
HDO high-speed pulse output
P06.17
Lower output limit of AO1
The above function codes define the relative   relationship between the output value and analog output. When the output   value exceeds the range of set maximum or minimum output, it will count   according to the low-limit or upper-limit output.
When the analog output is current output, 1mA   equals to 0.5V.
In different cases, the corresponding analog   output of 100% of the output value is different. See each application for   detailed information.
Setting range of P06.18: 0.00V–10.00V
Setting range of P06.19: P06.17–100.0%
Setting range of P06.20: 0.00V–10.00V
Setting range of P06.21: 0.000s–10.000s
Setting range of P06.22: -100.0%–P06.24
Setting range of P06.23: 0.00V–10.00V
Setting range of P06.24: P06.22–100.0%
Setting range of P06.25: 0.00V–10.00V
Setting range of P06.26: 0.000s–10.000s
Setting range of P06.27: -100.0%–P06.29
Setting range of P06.28: 0.00–50.00kHz
Setting range of P06.29: P06.27–100.0%
Setting range of P06.30: 0.00–50.00kHz
Setting range of P06.31: 0.000s–10.000s
0.0%
P06.18
Corresponding AO1 output of lower limit
0.00V
P06.19
Upper output limit of AO1
100.0%
P06.20
The corresponding AO1 output of upper limit
10.00V
P06.21
AO1 output filter time
0.000s
P06.22
Lower output limit of AO2
0.0%
P06.23
Corresponding AO2 output of lower limit
0.00V
P06.24
Upper output limit of AO2
100.0%
P06.25
The corresponding AO2 output of upper limit
10.00V
P06.26
AO2 output filter time
0.000s
P06.27
Lower output limit of HDO
0.0%
P06.28
Corresponding HDO output of lower limit
0.00
kHz
P06.29
Upper output limit of HDO
100.0%
P06.30
Corresponding HDO output of upper limit
50.00
kHz
P06.31
HDO output filter time
0.000s
