Function    code
Default    value
Modify
P07.00
User’s password
0–65535
The   password protection will be valid when setting any non-zero number.
00000: Clear   the previous user’s password, and make the password protection invalid.
After the   set user’s password becomes valid, if the password is incorrect, users cannot   enter the parameter menu. Only correct password can make the user check or   modify the parameters. Please remember all users’ passwords.
Retreat   editing state of the function codes and the password protection will become   valid in minute. If the valid password is available, press PRG/ESC   to enter into the editing state of the function codes, and then "0.0.0.0.0"   will be displayed. Unless input right password, the operator cannot enter   into it.
Note: Restoring to the   default value can clear the password, use it with caution.
P07.01
Parameter copy
The function code determines the manner of   parameters copy.
0: No operation
1: Upload the local function parameter to   the keypad
2: Download the keypad function parameter   to local address (including the motor parameters)
3: Download the keypad function parameter   to local address (excluding the motor parameter of P02 and P12 group)
4: Download the keypad function parameters   to local address (only for the motor parameter of P02 and P12 group)
Note: After   completing the 1–4 operations, the parameter will come back to 0 automatically;   the function of upload and download excludes the factory parameters of P29.
P07.02
QUICK/JOG function selection
0: No function
1: Jogging. Press QUICK/JOG to begin the   jogging running.
2: Shift the display state by the shifting   key. Press QUICK/JOG   to shift the displayed function code from right to left.
3: Shift between forward rotations and   reverse rotations. Press QUICK/JOG to shift the direction of the frequency   commands. This function is only valid in the keypad commands channels.
4: Clear UP/DOWN settings. Press QUICK/JOG   to clear the set value of UP/DOWN.
5: Coast to stop. Press QUICK/JOG to coast   to stop.
6: Shift the given manner of running   commands. Press QUICK/JOG to shift the given manner of running commands.
7: Quick commission mode (committee   according to the non-factory parameter)
Note: Press QUICK/JOG   to shift between forward rotation and reverse rotation, the VFD does not   remember the state after shifting during powering off. The VFD will run in   the running direction set according to parameter P00.13 during next powering   on.
P07.03
Shifting sequence selection ofQUICK/JOG   commands
When P07.02=6, set the shifting sequence of   running command channels.
0: Keypad control→terminals   control→communication control
1: Keypad control←→terminals control
2: Keypad control←→communication control
3: Terminals control←→communication control
P07.04
STOP/RST stop function
STOP/RST is valid for stop function. STOP/RST   is valid in any state for the fault reset.
0: Only valid for the keypad control
1: Both valid for keypad and terminals   control
2: Both valid for keypad and communication   control
3: Valid for all control modes
P07.05
Parameters state 1
0x0000–0xFFFF
BIT0: running frequency (Hz on)
BIT1: set frequency (Hz flickering)
BIT2: bus voltage (Hz on)
BIT3: output voltage (V on)
BIT4: output current (A on)
BIT5: running rotation speed (rpm on)
BIT6: output power (% on)
BIT7: output torque (% on)
BIT8: PID reference (% flickering)
BIT9: PID feedback value (% on)
BIT10: input terminals state
BIT11: output terminals state
BIT12: torque set value (% on)
BIT13: pulse counter value
BIT14: length value
BIT15: PLC and the current stage in multi-step   speed
0x03FF
P07.06
Parameters state 2
0x0000–0xFFFF
BIT0: AI1 (V on)
BIT1: AI2 (V on)
BIT2: AI3 (V on)
BIT3: HDI frequency
BIT4: motor overload percentage (% on)
BIT5: the VFD overload percentage (% on)
BIT6: ramp frequency given value (Hz on)
BIT7: linear speed
BIT8: AC inlet current (A on)
BIT9: upper limit frequency (Hz on)
BIT10–15: reserved
0x0000
P07.07
Parameters for stopping state
0x0000–0xFFFF
BIT0: set frequency (Hz on, frequency   flickering slowly)
BIT1: bus voltage (V on)
BIT2: input terminals state
BIT3: output terminals state
BIT4: PID reference (% flickering)
BIT5: PID feedback value (% on)
BIT6: torque reference (% on)
BIT7: AI1 (V on)
BIT8: AI2 (V on)
BIT9: AI3 (V on)
BIT10: HDI frequency
BIT11: PLC and the current stage in multi-step   speed
BIT12: pulse counters
BIT13: length value
BIT14: upper limit frequency (Hz on)
BIT15: reserved
0x00FF
P07.08
Frequency coefficient
0.01–10.00
Displayed frequency=running frequency × P07.08
1.00
P07.09
Rotation speed coefficient
0.1–999.9%
Mechanical rotation speed =120 × displayed   running frequency × P07.09/motor pole pairs
100.0%
P07.10
Linear speed coefficient
0.1–999.9%
Linear speed= Mechanical rotation speed × P07.10
1.0%
P07.11
Rectifier bridge module temperature
-20.0–120.0°C
P07.12
Inverter module temperature
-20.0–120.0°C
P07.13
Software version
1.00–655.35
P07.14
Local accumulative running time
0–65535h
P07.15
High bit of power consumption
Display the power used by the VFD.
The power consumption of the VFD =P07.15×1000+P07.16
Setting range of P07.15: 0–65535kWh (×1000)
Setting range of P07.16: 0.0–999.9kWh
P07.16
Low bit of power consumption
P07.17
Reserved
Reserved
P07.18
The rated power of the VFD
0.4–3000.0kW
P07.19
The rated voltage of the VFD
50–1200V
P07.20
The rated current of the VFD
0.1–6000.0A
P07.21
Factory bar code 1
0x0000–0xFFFF
P07.22
Factory bar code 2
0x0000–0xFFFF
P07.23
Factory bar code 3
0x0000–0xFFFF
P07.24
Factory bar code 4
0x0000–0xFFFF
P07.25
Factory bar code 5
0x0000–0xFFFF
P07.26
Factory bar code 6
0x0000–0xFFFF
P07.27
Current fault type
0: No fault
1: Inverter unit U phase protection(OUt1)
2: Inverter unit V phase protection(OUt2)
3: Inverter unit W phase protection(OUt3)
4: ACC   overcurrent (OC1)
5: DEC   overcurrent (OC2)
6:   Constant-speed overcurrent (OC3)
7: ACC   overvoltage (OV1)
8: DEC   overvoltage (OV2)
9:   Constant-speed overvoltage (OV3)
10: Bus undervoltage (UV)
11: Motor overload (OL1)
12: The VFD overload (OL2)
13: Input side phase loss (SPI)
14: Output side phase loss (SPO)
15: Overheat of the rectifier module (OH1)
16: Overheat fault of the inverter module (OH2)
17: External fault (EF)
18: 485 communication fault (CE)
19: Current detection fault (ItE)
20: Motor antotune fault (tE)
21: EEPROM operation fault (EEP)
22: PID response offline fault (PIDE)
23: Braking unit fault (bCE)
24: Running time arrival (END)
25: Electrical overload (OL3)
26: Panel communication fault (PCE)
27: Parameter uploading fault (UPE)
28: Parameter downloading fault (DNE)
29: PROFIBUS communication fault (E-DP)
30: Ethernet communication fault (E-NET)
31: CANopen   communication fault (E-CAN)
32: Grounding short circuit fault 1 (ETH1)
33: Grounding short circuit fault 2 (ETH2)
34: Speed deviation fault (dEu)
35: Maladjustment (STo)
36: Undervoltage fault (LL)
P07.28
Previous fault type
P07.29
Previous 2 fault type
P07.30
Previous 3 fault type
P07.31
Previous 4 fault type
P07.32
Previous 5 fault type
P07.33
Running frequency at current fault
0.00Hz
P07.34
Ramp reference frequency at current fault
0.00Hz
P07.35
Output voltage at current fault
0V
P07.36
Output current at current fault
0.0A
P07.37
Bus voltage at current fault
0.0V
P07.38
The Max. temperature at current fault
0.0°C
P07.39
Input terminals state at current fault
P07.40
Output terminals state at current fault
P07.41
Running frequency at last fault
0.00Hz
P07.42
Ramp reference frequency at last fault
0.00Hz
P07.43
Output voltage at last fault
0V
P07.44
The output current at last fault
0.0A
P07.45
Bus voltage at last fault
0.0V
P07.46
The Max. temperature at last fault
0.0°C
P07.47
Input terminals state at last fault
P07.48
Output terminals state at last fault
P07.49
Runnig frequency at last but one fault
0.00Hz
P07.50
Output voltage at last but one faults
0.00Hz
P07.51
Output current at last but one faults
0V
P07.52
0.0A
P07.53
Bus voltage at last but one fault
0.0V
P07.54
The Max. temperature at last but one fault
0.0°C
P07.55
Input terminals state at last but one fault
P07.56
Output terminals state at last but one   fault
