The VFD keypad can display the stopped-state parameters, running-state parameters, function parameter editing status, and fault alarm status.
5.3.1 Displaying stopped-state parameters
When the VFD is in stopped state, the keypad displays stopped state parameters, and this interface is the main interface during power-on by default. In stopped state, parameters in various states can be
displayed. Press image.png or image.png to shift the displayed parameters upward or downward.
Press image.png or image.png to switch between different display styles, including list display style and progress bar display style.
The stopped display parameter list is user defined, and each state variable function code can be added to the stop display parameter list as needed. The state variable which has been added to the stop display parameter list can also be deleted or shifted.
5.3.2 Displaying running-state parameters
After receiving valid running command, the VFD will enter running state, and the keypad displays running state parameter with RUN indicator on the keypad turning on. Under running state, multiple kinds of state parameters can be displayed. Press image.png or image.png to shift up or down.
Under running state, multiple kinds of state parameters can be displayed. The running display parameter list is defined by the user, and each state variable function code can be added to the running display parameter list as needed. The state variable which has been added to the running display parameter list can also be deleted or shifted.
5.3.3 Displaying fault information
The VFD enters fault alarm display state once fault signal is detected, and the keypad displays fault code and fault information with TRIP indicator on the keypad turning on. Fault reset operation can be carried out via STOP/RST key, control terminal or communication command.
The fault code will be kept displaying until fault is removed.
