5.5.5 Torque control
The VFD supports torque control and speed control. Speed control aims to stabilize the speed to keep the set speed consistent with the actual running speed, meanwhile, the max. load-carrying capacity is restricted by the torque limit. Torque control aims to stabilize the torque to keep the set torque consistent with the actual output torque, meanwhile, the output frequency is restricted by the upper and lower limits.
Function code
Description
Default
P00.00
Speed control mode
0: Sensorless vector control (SVC) mode 0
1: Sensorless vector control (SVC) mode 1
2: Space voltage vector control mode
3: Closed-loop vector control mode
Note: To select 0, 1, or 3 as the control mode, enable the VFD to   perform motor parameter autotuning first.
P03.32
Enabling torque control
0: Disable
1: Enable
P03.11
Torque setting method
1: Keypad (P03.12)
2: AI1 (100% corresponding to three times   the motor rated current)
3: AI2 (same as the above)
4: AI3 (same as the above)
5: Pulse frequency HDIA (same as the above)
6: Multi-step torque (same as the above)
7: Modbus/Modbus TCP communication (same as   the above)
8: Profibus/CANopen/DeviceNet  communication (same as the above)
9: Ethernet communication (same as the   above)
10: Pulse frequency HDIB (same as the above)
11: EtherCat/Profinet/EtherNetIP communication
12: Programmable expansion card
Note: For setting methods 2–12, 100%   corresponds to three times the motor rated current.
P03.12
Torque set through keypad
-300.0%–300.0% (of the motor rated current)
50.0%
P03.13
Torque reference filter time
0.000–10.000s
0.010s
P03.14
Setting source of forward rotation   upper-limit frequency in torque control
0: Keypad (P03.16)
1: AI1 (100% corresponding to the max. frequency)
2: AI2 (same as the above)
3: AI3 (same as the above)
4: Pulse frequency HDIA (same as the above)
5: Multi-step setting (same as the above)
6: Modbus/Modbus   TCP communication (same as the above)
7: Profibus/CANopen/DeviceNet communication (same as the above)
8: Ethernet communication (same as the above)
9: Pulse frequency HDIB (same as the above)
10: EtherCat/Profinet/EtherNetIP communication
11: Programmable expansion card
12: Reserved
Note: For setting methods 1–11, 100%   corresponds to the maximum frequency.
P03.15
Setting source of reverse rotation   upper-limit frequency in torque control
0: Keypad   (P03.17)
12: Reserved
P03.16
Forward rotation upper-limit frequency set   through keypad in torque control
0.00Hz–P00.03 (Max. output frequency)
50.00 Hz
P03.17
Reverse rotation upper-limit frequency set   through keypad in torque control
50.00 Hz
P03.18
Setting source of electromotive torque   upper limit
0: Keypad (P03.20)
1: AI1 (100% corresponding to three times   the motor rated current)
5: Modbus/Modbus TCP communication (same as   the above)
6: Profibus/CANopen/DeviceNet communication   (same as the above)
7: Ethernet communication (same as the   above)
8: Pulse frequency HDIB (same as the above)
9: EtherCat/Profinet/EtherNetIP communication
10: Programmable expansion card
11: Reserved
Note: For setting methods 1–10, 100%   corresponds to three times the motor rated current.
P03.19
Setting source of braking torque upper   limit
0: Keypad (P03.21)
11: Reserved
P03.20
Electromotive torque upper limit set   through keypad
0.0–300.0% (of the motor rated current)
180.0%
P03.21
Braking torque upper limit set through   keypad
180.0%
P17.09
Output torque
-250.0–250.0%
0.0%
P17.15
Torque reference value
-300.0–300.0% (of the motor rated current)
0.0%
5.5.6 Motor parameters
² Check the safety   conditions surrounding the motor and load machineries before autotuning as   physical injury may occur due to sudden start of motor during autotuning.
² Although the motor   does not run during static autotuning, the motor is still supplied with   power. Do not touch the motor during autotuning; otherwise, electric shock   may occur. Do not touch the motor before autotuning is completed.
² If the motor has been   connected to a load, do not carry out rotary autotuning. Otherwise, the VFD   may malfunction or may be damaged. If rotary autotuning is carried out on a   motor which has been connected to a load, incorrect motor parameter settings   and motor action exceptions may occur. Disconnect from the load to carry out   autotuning if necessary.
The VFD can drive both asynchronous motors and synchronous motors, and it supports two sets of motor parameters, which can be switched over by multifunction digital input terminals or communication modes.
The control performance of the VFD is based on accurate motor models. Therefore, you need to carry out motor parameter autotuning before running a motor for the first time (taking motor 1 as an example).
l Motor parameters must be set correctly according to the motor nameplate.
l If rotary autotuning is selected during motor autotuning, disconnect the motor from the load to put the motor in static and no-load state. Otherwise, the motor parameter autotuning results may be incorrect. In addition, autotune P02.06P02.10 for AMs and autotune P02.20P02.23 for SMs.
l If static autotuning is selected for motor autotuning, there is no need to disconnect the motor from the load, but the control performance may be impacted as only a part of the motor parameters have been autotuned. In addition, autotune P02.06P02.10 for AMs and autotune P02.20P02.22 for SMs. P02.23 can be obtained through calculation.
l Motor autotuning can be carried out on the present motor only. If you need to perform autotuning on the other motor, switch the motor through selecting the switchover channel of motor 1 and motor 2 by setting the ones place of P08.31.
Related parameter list:
Function code
Description
Default
P00.01
Channel   of running commands
0:   Keypad
1:   Terminal
2:   Communication
P00.15
Motor parameter autotuning
0: No operation
1: Rotary   autotuning 1.
Comprehensive   motor parameter autotuning. It is recommended to use rotating autotuning when   high control accuracy is needed.
2:   Static autotuning 1 (comprehensive autotuning); static autotuning 1 is used   in cases where the motor cannot be disconnected from load.
3:   Static autotuning 2 (partial autotuning); when the present motor is motor 1,   only P02.06, P02.07 and P02.08 are autotuned; when the present motor is motor 2,   only P12.06, P12.07 and P12.08 are autotuned.
4: Rotary autotuning 2. Similar to rotary autotuning 1, but it is   valid only for AMs.
5: Static autotuning 3 (partial autotuning), valid only for AMs.
P02.00
Type   of motor 1
0:   Asynchronous motor (AM)
1:   Synchronous motor (SM)
P02.01
Rated   power of AM 1
0.1–3000.0kW
Model depended
P02.02
Rated   frequency of AM 1
0.01Hz–P00.03 (Max. output frequency)
50.00Hz
P02.03
Rated   speed of AM 1
1–60000rpm
Model depended
P02.04
Rated   voltage of AM 1
0–1200V
Model depended
P02.05
Rated   current of AM 1
0.8–6000.0A
Model depended
P02.06
Stator   resistance of AM 1
0.001–65.535Ω
Model depended
P02.07
Rotor   resistance of AM 1
0.001–65.535Ω
Model depended
P02.08
Leakage   inductance of AM 1
0.1–6553.5mH
Model depended
P02.09
Mutual   inductance of AM 1
0.1–6553.5mH
Model depended
P02.10
No-load   current of AM 1
0.1–6553.5A
Model depended
P02.15
Rated   power of SM 1
0.1–3000.0kW
Model depended
P02.16
Rated   frequency of SM 1
50.00Hz
P02.17
Number   of pole pairs of SM 1
1–50
P02.18
Rated   voltage of SM 1
0–1200V
Model depended
P02.19
Rated   current of SM 1
0.8–6000.0A
Model depended
P02.20
Stator   resistance of SM 1
0.001–65.535Ω
Model depended
P02.21
Direct-axis   inductance of SM 1
0.01–655.35mH
Model depended
P02.22
Quadrature-axis   inductance of SM 1
0.01–655.35mH
Model depended
P02.23
Counter-emf   constant of SM 1
0–10000
300
P05.01P05.06
Function   selection of multifunction digital input terminals (S1–S4, HDIA, HDIB)
35: Switch from motor 1 to motor 2
P08.31
Switching   between motor 1 and motor 2
0x00–0x14
Ones   place: Switchover channel
0:   Terminal
1: Modbus/Modbus   TCP communication
2:   Profibus/CANopen/DeviceNet communication
3: Ethernet communication
4: EtherCat/Profinet/EtherNetIP communication
Tens   place: indicates whether to enable switchover during running
0:   Disable
1: Enable
00
P12.00
Type   of motor 2
P12.01
Rated   power of AM 2
0.1–3000.0kW
Model depended
P12.02
Rated   frequency of AM 2
50.00Hz
P12.03
Rated   speed of AM 2
1–60000rpm
Model depended
P12.04
Rated   voltage of AM 2
0–1200V
Model depended
P12.05
Rated   current of AM 2
0.8–6000.0A
Model depended
P12.06
Stator   resistance of AM 2
0.001–65.535Ω
Model depended
P12.07
Rotor   resistance of AM 2
0.001–65.535Ω
Model depended
P12.08
Leakage   inductance of AM 2
0.1–6553.5mH
Model depended
P12.09
Mutual   inductance of AM 2
0.1–6553.5mH
Model depended
P12.10
No-load   current of AM 2
0.1–6553.5A
Model depended
P12.15
Rated   power of SM 2
0.1–3000.0kW
Model depended
P12.16
Rated   frequency of SM 2
50.00Hz
P12.17
Number   of pole pairs of SM 2
1–50
P12.18
Rated   voltage of SM 2
0–1200V
Model depended
P12.19
Rated   current of SM 2
0.8–6000.0A
Model depended
P12.20
Stator   resistance of SM 2
0.001–65.535Ω
Model depended
P12.21
Direct-axis   inductance of SM 2
0.01–655.35mH
Model depended
P12.22
Quadrature-axis   inductance of SM 2
0.01–655.35mH
Model depended
P12.23
Counter-emf   constant of SM 2
0–10000
300
5.5.7 Start/stop control
The start/stop control of the VFD involves three states: start after a running command is given at power-on; start after power-off restart is effective; start after automatic fault reset. The three start/stop control states are described in the following.
There are three start modes for the VFD, which are start at starting frequency, start after DC braking, and start after speed tracking. You can select the proper start mode based on actual conditions.
For large-inertia load, especially in cases where reversal may occur, you can choose to start after DC braking or start after speed tracking.
Note: It is recommended to drive SMs in direct start mode.
(1)     Logic diagram for start after a running command is given at power-on
(2)     Logic diagram for start after power-off restart is effective
(3)     Logic diagram for start after automatic fault reset
Function code
Description
Default
P00.01
0: Keypad
1: Terminal
2: Communication
P00.11
ACC time 1
0.0–3600.0s
Model depended
P00.12
DEC time 1
0.0–3600.0s
Model depended
P01.00
Start mode
0: Direct start
1: Start after DC braking
2: Speed tracking restart 1
3: Speed tracking restart 2
P01.01
Starting frequency of direct start
0.00–50.00Hz
0.50Hz
P01.02
Starting frequency hold time
0.0–50.0s
0.0s
P01.03
Braking current before start
0.0–100.0%
0.0%
P01.04
DC braking time before start
0.00–50.00s
0.00s
P01.05
ACC and DEC mode
0: Linear
1: S curve
Note: If mode 1 is selected, set P01.06, P01.07, P01.27, and P01.28   accordingly.
P01.08
Stop mode
0: Decelerate to stop
1: Coast to stop
P01.09
Starting frequency of DC braking for stop
0.00Hz
P01.10
Wait time before DC braking for stop
0.00–50.00s
0.00s
P01.11
DC braking current for stop
0.0–100.0%
0.0%
P01.12
DC braking time for stop
0.00–50.00s
0.00s
P01.13
FWD/REV running deadzone time
0.0–3600.0s
0.0s
P01.14
FWD/REV running switching mode
0: Switch at zero frequency
1: Switch at the starting frequency
2: Switch after the speed reaches the stop   speed with a delay
P01.15
Stop speed
0.00–100.00Hz
0.50 Hz
P01.16
Stop speed detection mode
0: Detect by the set speed (unique in space   voltage vector control mode)
1: Detect by the feedback speed
P01.18
Terminal-based running command protection   at power-on
0: The terminal running command is invalid   at power-on
1: The terminal running command is valid at   power-on
P01.19
Action selected when running frequency   less than frequency lower limit (valid when frequency lower limit greater   than 0)
0: Run at the frequency lower limit
1: Stop
2: Sleep
P01.20
Wake-up-from-sleep delay
0.0–3600.0s (valid when P01.19=2)
0.0s
P01.21
Power-off restart selection
0: Disable
1: Enable
P01.22
Wait time for power-on restart
0.0–3600.0s (valid when P01.21=1)
1.0s
P01.23
Start delay
0.0–60.0s
0.0s
P01.24
Stop speed delay
0.0–100.0s
0.0s
P01.25
Open-loop 0Hz output selection
0: Output without voltage
1: Output with voltage
2: Output with the DC braking current for   stop
P01.26
DEC time for emergency stop
0.0–60.0s
2.0s
P01.27
Time of starting segment of DEC S curve
0.0–50.0s
0.1s
P01.28
Time of ending segment of DEC S curve
0.0–50.0s
0.1s
P01.29
Short-circuit braking current
0.0–150.0% (of the VFD rated current)
0.0%
P01.30
Hold time of short-circuit braking for start
0.00–50.00s
0.00s
P01.31
Hold time of short-circuit braking for   stop
0.00–50.00s
0.00s
P01.32
Pre-exciting   time of jog
0–10.000s
0.000s
P01.33
Starting   frequency of braking for jogging to stop
0–P00.03
0.00Hz
P01.34
Delay   to enter sleep
0–3600.0s
0.0s
P05.01P05.06
Digital input function selection
1: Run forward
2: Run reversely
4: Jog forward
5: Jog reversely
6: Coast to stop
7: Reset faults
8: Pause running
21: ACC/DEC time selection 1
22: ACC/DEC time selection 2
30: Disable ACC/DEC
P08.00
ACC time 2
0.0–3600.0s
Model depended
P08.01
DEC time 2
0.0–3600.0s
Model depended
P08.02
ACC time 3
0.0–3600.0s
Model depended
P08.03
DEC time 3
0.0–3600.0s
Model depended
P08.04
ACC time 4
0.0–3600.0s
Model depended
P08.05
DEC time 4
0.0–3600.0s
Model depended
P08.06
Running frequency of jog
5.00Hz
P08.07
ACC time for jog
0.0–3600.0s
Model depended
P08.08
DEC time for jog
0.0–3600.0s
Model depended
P08.19
Switching frequency of ACC/DEC time
0.00–P00.03(Max. output frequency)
0.00Hz: No switchover
If the running frequency is greater than P08.19,   switch to ACC/DEC time 2.
P08.21
Reference frequency of ACC/DEC time
0: Max. output frequency
1: Set frequency
2: 100Hz
Note: Valid only for straight-line   ACC/DEC
P08.28
Auto fault reset count
0–10
P08.29
Auto fault reset interval
0.1–3600.0s
1.0s
5.5.8 Frequency setting
The VFD supports multiple frequency setting methods, which can be divided into two types: main reference channel and auxiliary reference channel.
There are two main reference channels, namely frequency reference channel A and frequency reference channel B. These two channels support simple arithmetical operation between each other, and they can be switched dynamically by setting multi-function terminals.
There is one input mode for auxiliary reference channel, namely terminal UP/DOWN switch input. By setting function codes, you can enable the corresponding reference mode and the impact made on the VFD frequency reference by this reference mode.
The actual reference of VFD is comprised of the main reference channel and auxiliary reference channel.
The VFD supports switchover between different reference channels, and the rules for channel switchover are shown in the following.
Present    reference channel
P00.09
Multifunction terminal function 13
Channel A switched to channel B
Multifunction terminal function 14
Combination    setting switched to channel A
Multifunction terminal function 15
Combination    setting switched to channel B
A
B
B
A
A+B
A
B
A-B
A
B
Max(A,B)
A
B
Min(A,B)
A
B
Note: "/" indicates this multifunction terminal is invalid under present reference channel.
When setting the auxiliary frequency inside the VFD via multi-function terminal UP (10) and DOWN (11), you can increase/decrease the frequency quickly by setting P08.45 (UP terminal frequency incremental change rate) and P08.46 (DOWN terminal frequency decrement change rate).
Function code
Description
Default
P00.03
P00.04–400.00Hz
50.00Hz
P00.04
Upper limit of running frequency
P00.05P00.03
50.00Hz
P00.05
Lower limit of running frequency
0.00Hz–P00.04
0.00Hz
P00.06
Setting channel of A frequency command
0:   Keypad
1: AI1
2: AI2
3: AI3
4:   High-speed pulse HDIA
5:   Simple PLC program
6:   Multi-step speed running
7: PID   control
8:   Modbus/Modbus TCP communication
9:   Profibus/CANopen/DeviceNet communication
10:   Ethernet communication
11:   High-speed pulse HDIB
12:   Pulse train AB
13:   EtherCat/Profinet/EtherNetIP communication
14:   Programmable expansion card
15:   Reserved
P00.07
Setting channel of B frequency command
15
P00.08
Reference object of B frequency command
1: A   frequency command
P00.09
Combination mode of setting source
0: A
1: B
2: (A+B)
3: (A-B)
4: Max(A, B)
5: Min.   (A, B)
P05.01P05.06
10: Increase frequency setting (UP)
11: Decrease frequency setting (DOWN)
12: Clear the frequency increase/decrease   setting
13: Switch between A setting and B setting
14: Switch between combination setting and   A setting
15:   Switch between combination setting and B setting
P08.42
Reserved
P08.43
Reserved
P08.44
UP/DOWN   terminal control setting
0x000–0x221
Ones place: Frequency setting selection
0: The setting made through UP/DOWN   is valid.
1: The setting made through UP/DOWN   is invalid.
Ones   place: Frequency control selection
0:   Valid only when P00.06=0 or P00.07=0
1: Valid for all frequency setting methods
2: Invalid for multi-step speed running   when multi-step speed running has the priority
Hundreds place: Action selection for stop
0: Setting is valid.
1: Valid during running, cleared after stop
2:   Valid during running, cleared after a stop command is received
0x000
P08.45
Frequency increment change rate of the UP   terminal
0.01–50.00   Hz/s
0.50 Hz/s
P08.46
Frequency decrement change rate of the   DOWN terminal
0.01–50.00   Hz/s
0.50 Hz/s
P17.00
Set frequency
0.00Hz
P17.02
Ramp reference frequency
0.00Hz
P17.14
Digital adjustment value
0.00Hz–P00.03
0.00Hz
5.5.9 Analog input
The VFD provides two analog input terminals, which are AI1 supporting 0–10V/0–20mA, (whether the input is voltage or current can be set by P05.50), and AI2 supporting -10–10V, and two high-speed pulse input terminals. Each input can be filtered separately, and the corresponding reference curve can be set by adjusting the reference corresponds to the max. value and min. value.
Function code
Description
Default
P05.00
HDI input type
0x00–0x11
Ones place: HDIA input type
0: HDIA is high-speed pulse input
1: HDIA is digital input
Tens place: HDIB input type
0: HDIB is high-speed pulse input
1: HDIB is digital input
0x00
P05.24
AI1 lower limit
0.00V–P05.26
0.00V
P05.25
Corresponding setting of AI1 lower limit
-300.0%–300.0%
0.0%
P05.26
AI1 upper limit
P05.24–10.00V
10.00V
P05.27
Corresponding setting of AI1 upper limit
-300.0%–300.0%
100.0%
P05.28
AI1 input filter time
0.000s–10.000s
0.100s
P05.29
AI2 lower limit
-10.00V–P05.31
-10.00V
P05.30
Corresponding setting of AI2 lower limit
-300.0%–300.0%
-100.0%
P05.31
AI2 middle value 1
P05.29P05.33
0.00V
P05.32
Corresponding setting of AI2 middle value   1
-300.0%–300.0%
0.0%
P05.33
AI2 middle value 2
P05.31P05.35
0.00V
P05.34
Corresponding setting of AI2 middle value   2
-300.0%–300.0%
0.0%
P05.35
AI2 upper limit
P05.33–10.00V
10.00V
P05.36
Corresponding setting of AI2 upper limit
-300.0%–300.0%
100.0%
P05.37
AI2 input filter time
0.000s–10.000s
0.100s
P05.38
HDIA high-speed pulse input function   selection
0: Input set through frequency
1: Reserved
2: Input set through encoder, used together with HDIB
P05.39
HDIA lower limit frequency
0.000 kHz – P05.41
0.000kHz
P05.40
Corresponding setting of HDIA lower limit   frequency
-300.0%–300.0%
0.0%
P05.41
HDIA upper limit frequency
P05.39 –50.000kHz
50.000kHz
P05.42
Corresponding setting of HDIA upper limit   frequency
-300.0%–300.0%
100.0%
P05.43
HDIA frequency input filter time
0.000s–10.000s
0.030s
P05.44
HDIB high-speed pulse input function   selection
1: Reserved
2: Input set through encoder, used together with HDIA
P05.45
HDIB lower limit frequency
0.000 kHz – P05.47
0.000kHz
P05.46
Corresponding setting of HDIB lower limit   frequency
-300.0%–300.0%
0.0%
P05.47
HDIB upper limit frequency
P05.45 –50.000kHz
50.000kHz
P05.48
Corresponding setting of HDIB upper limit   frequency
-300.0%–300.0%
100.0%
P05.49
HDIB frequency input filter time
0.000s–10.000s
0.030s
P05.50
AI1 input signal type
0–1
0: Voltage
1: Current
5.5.10 Analog output
The VFD provides one analog output terminal (supporting 0–10V/0–20mA) and one high-speed pulse output terminal. Analog output signals can be filtered separately, and the proportional relation can be adjusted by setting the max. value, min. value, and the percentage of their corresponding output. Analog output signals can output the motor speed, output frequency, output current, motor torque and motor power at a certain proportion.
Terminal output is described as follows:
Setting
Function
Description
Running frequency
0–Max. output frequency
Set frequency
3
Running speed
0–Synchronous speed corresponding to max.   output frequency
4
Output current (relative to VFD)
0–Twice the VFD rated current
5
Output current (relative to motor)
0–Twice the motor rated current
6
Output voltage
0–1.5 times the VFD rated voltage
7
Output power
0–Twice the rated power
8
Set torque value (bipolar)
0–Twice the VFD rated current. A negative   value corresponds to 0.0% by default.
9
Output torque (absolute value)
0 – +/-(Twice the motor rated torque)
10
AI1 input
0–10V/0–20mA
11
AI2 input
0V–10V. A negative value corresponds to   0.0% by default.
12
AI3 input
0–10V/0–20mA
13
High-speed pulse HDIA input
0.00–50.00kHz
14
Value 1 set through Modbus/Modbus TCP   communication
0–1000
15
Value 2 set through Modbus/Modbus TCP   communication
0–1000
16
Value 1 set through   PROFIBUS/CANopen/DeviceNet communication
0–1000
17
Value 2 set through   PROFIBUS/CANopen/DeviceNet communication
0–1000
18
Value 1 set through Ethernet   communication
0–1000
19
Value 2 set through Ethernet   communication
0–1000
20
0.00–50.00kHz
21
Value 1 set through   EtherCAT/Profinet/EtherNetIP communication
0–1000. A negative value corresponds to   0.0% by default.
22
Torque current (bipolar)
0–Three times the motor rated current. A   negative value corresponds to 0.0% by default.
23
Exciting current
24
Set frequency (bipolar)
0–Max. output frequency. A negative value   corresponds to 0.0% by default.
25
Ramp reference frequency (bipolar)
26
Rotational speed (bipolar)
0–Synchronous speed corresponding to max. output   frequency A negative value corresponds to 0.0% by default.
27
Value 2 set through   EtherCat/Profinet/EtherNetIP communication
0–1000
28
C_AO1 from PLC
0–1000
29
C_AO2 from PLC
0–1000
30
Rotational speed
0–Twice the motor rated synchronous speed
31
Output torque (bipolar)
0–Twice motor rated torque. A negative   value corresponds to 0.0% by default.
31–47
Reserved
