A.6.1 Bluetooth communication card––EC-TX501 and WIFI communication card——EC-TX502
Definitions of indicators and function buttons:
Indicator/button
Function
LED1/LED3
Bluetooth/WIFI   state indicator
The indicator is on when the expansion card is   establishing a connection with the control board; it blinks periodically   after the expansion card is properly connected to the control board (the   period is 1s, on for 0.5s, and off for the other 0.5s); and it is off when   the expansion card is disconnected from the control board.
LED2
Bluetooth   communication state indicator
This indicator is on when Bluetooth communication   is online and data exchange can be performed.
It is off when Bluetooth communication is not in   the online state.
LED5
Power indicator
This indicator is on after the control board   feeds power to the Bluetooth card.
SW1
WIFI factory   reset button
It is restored to default values and returned to the local monitoring mode.
SW2
WIFI hardware   reset button
It is used to reboot the expansion card.
The wireless communication card is especially useful for scenarios where you cannot directly use the keypad to operate the VFD due to the restriction of the installation space. With a mobile phone APP, you can operate the VFD in a maximum distance of 30 m. You can choose a PCB antenna or an external sucker antenna. If the VFD is located in an open space and is a molded case machine, you can use a built-in PCB antenna; and if it is a sheetmetal machine and located in a metal cabinet, you need to use an external sucker antenna.
When installing a sucker antenna, install a wireless communication card on the VFD first, and then lead the SMA connector of the sucker antenna into the VFD and screw it to CN2, as shown in the following figure. Place the antenna base on the chassis and expose the upper part. Try to keep it unblocked.
The wireless communication card must be used with the INVT VFD APP. Scan the QR code of the VFD nameplate to download it. For details, refer to the wireless communication card manual provided with the expansion card. The main interface is shown as follows.
A.6.2 PROFIBUS-DP communication card——EC-TX503
CN1 is a 9-pin D-type connector, as shown in the following figure.
Connector pin
Description
Unused
Unused
3
B-Line
Data+ (twisted pair 1)
4
RTS
Request sending
5
GND_BUS
Isolation ground
6
+5V BUS
Isolated power supply of 5 V DC
7
Unused
8
A-Line
Data- (twisted pair 2)
9
Unused
Housing
SHLD
PROFIBUS cable shielding line
+5V and GND_BUS are bus terminators. Some devices, such as the optical transceiver (RS485), may need to obtain power through these pins.
On some devices, the transmission and receiving directions are determined by RTS. In normal applications, only A-Line, B-Line, and the shield layer need to be used.
Indicator definition
Indicator
Function
LED1
State indicator
This indicator is on when the expansion card is establishing a   connection with the control board; it blinks periodically after the expansion   card is properly connected to the control board (the period is 1s, on for   0.5s, and off for the other 0.5s); and it is off when the expansion card is   disconnected from the control board.
LED2
Online indicator
This indicator is on when the communication card is online and data   exchange can be performed.
It is off when the communication card is not in the online state.
LED3
Offline/Fault indicator
This indicator is on when the communication card is offline and data   exchange cannot be performed.
It blinks when the communication card is not in the offline state.
It blinks at the frequency of 1 Hz when a configuration error occurs:   The length of the user parameter data set during the initialization of the   communication card is different from that during the network configuration.
It blinks at the frequency of 2 Hz when user parameter data is   incorrect: The length or content of the user parameter data set during the   initialization of the communication card is different from that during the   network configuration.
It blinks at the frequency of 4 Hz when an error occurs in the ASIC   initialization of PROFIBUS communication.
It is off when the diagnosis function is disabled.
LED4
Power indicator
This indicator is on after the control board feeds power to the   communication card.
For details about the operation, see the Goodrive350 Series VFD Communication Expansion Card Operation Manual.
A.6.3 Ethernet communication card——EC-TX504
The EC-TX504 communication card adopts standard RJ45 terminals.
Indicator definition:
Indicator
Function
LED1
State indicator
LED2
LINK   indicator (Green)
It is on when the connection to the upper computer is normal; it is   off when the upper computer is disconnected.
LED3
ACK indicator (Red)
It is on when there is data to return to the upper computer; it is off   when there is no data to return to the upper computer.
LED4
Power indicator
A.6.4 CANopen communication card——EC-TX505 and CAN master/slave control communication card EC-TX511
The EC-TX505/511 communication card is user-friendly, adopting spring terminals.
3-pin spring terminal
Pin
Function
Description
CANH
CANopen bus high level   signal
CANG
CANopen bus shielding
3
CANL
CANopen bus low level signal
Terminal resistor switch function description:
Position
Function
Description
Left
OFF
CAN_H and CAN_L are not connected to a terminal resistor.
Right
ON
CAN_H and CAN_L are connected to a terminal resistor of 120 Ω.
Indicator
Function
LED1
State indicator
LED4
Power indicator
LED5
Running indicator
This indicator is on when the communication card is in the working   state.
It is off when a fault occurs. Check whether the reset pin of the   communication card and the power supply are properly connected.
It blinks when the communication card is in the pre-operation state.
It blinks once when the communication card is in the stopped state.
LED6
Error indicator
This indicator is on when the CAN controller bus is off or a fault   occurs on the VFD.
It is off when the communication card is in the working state.
It blinks when the address setting is incorrect.
It blinks once when a received frame is missed or an error occurs   during frame receiving.
A.6.5 PROFINET communication card——EC-TX509
The terminal CN2 adopts a standard RJ45 interface, where CN2 is the dual RJ45 interface, and these two RJ45 interfaces are not distinguished from each other and can be interchangeably inserted. They are arranged as follows:
Pin
Description
TX+
Transmit Data+
TX-
Transmit Data-
3
RX+
Receive Data+
4
n/c
Not connected
5
n/c
Not connected
6
RX-
Receive Data-
7
n/c
Not connected
8
n/c
Not connected
The PROFINET communication card has 9 indicators, of which LED1 is the power indicator, LED2–5 are the communication state indicators of the communication card, and LED6–9 are the state indicators of the network port.
LED
Color
State
Description
LED1
Green
3.3V power indicator
LED2
(Bus state indicator)
Red
On
No network connection
Blinking
The connection to the network cable between   the Profinet controller is OK, but the communication is not established.
Off
Communication with the Profinet controller   has been established
LED3
(System fault indicator)
Green
On
Profinet diagnosis exists
Off
No Profinet diagnosis
LED4
(Slave ready indicator)
Green
On
TPS-1 protocol stack has started
Blinking
TPS-1 waits for MCU initialization
Off
TPS-1 protocol stack does not start
LED5
(Maintenance state indicator)
Green
Manufacturer-specific - depending on the   characteristics of the device
LED6/7
(Network port state indicator)
Green
On
PROFINET communication card and PC/PLC have   been connected via a network cable
Off
PROFINET communication card and PC/PLC have   not been connected yet
LED8/9
(Network port communication indicator)
Green
On
PROFINET communication card and PC/PLC are   communicating
Off
PROFINET communication card and PC/PLC are   not yet communicating
Electrical connection:
The Profinet communication card adopts a standard RJ45 interface, which can be used in a linear network topology and a star network topology. The linear network topology electrical connection diagram is shown below.
Linear network topology electrical connection diagram
Note: For the star network topology, you need to prepare Profinet switches.
The star network topology electrical connection diagram is shown below:
