Function code
Default    value
Modify
P02.00
Motor
type 1
0: AM
1: SM
Note: Switch the current motor by the switching channel   of P08.31.
P02.01
Rated power of AM 1
0.1–3000.0 kW
Set the parameters   of the controlled AM.
In order to ensure   control performance, set the value of P02.01–P02.05 based on the nameplate   parameters.
Goodrive35 series VFD   provides parameter autotuning function. The accurate parameter autotuning   requires proper parameter setup.
In order to ensure   control performance, configure the motor based on the motor which matches   with the VFD. If the gap between motor power and the matched motor is too   large, the control performance of the VFD will be deteriorated greatly.
Note: P02.02–P02.10   can be initialized by resetting rated motor power P02.01.
Depend on model
P02.02
Rated frequency of AM 1
0.01 Hz–P00.03 (max.   output frequency)
50.00 Hz
P02.03
Rated speed of AM 1
1–36000rpm
Depend on model
P02.04
Rated voltage of AM 1
0–1200 V
Depend on model
P02.05
Rated current of AM 1
0.8–6000.0A
Depend on model
P02.06
Stator resistor of AM 1
0.001–65.535Ω
After motor   parameter autotuning finishes, the setting value of P02.06–P02.10 will be   updated automatically. These parameters are the basic parameters for   high-performance vector control, which will impact the control performance   directly.
Note: Users   cannot change this group of parameters at will.
Depend on model
P02.07
Rotor resistor of AM 1
0.001–65.535Ω
Depend on model
P02.08
Leakage inductance of AM 1
0.1–6553.5mH
Depend on model
P02.09
Mutual inductance of AM 1
0.1–6553.5mH
Depend on model
P02.10
Non-load current of AM 1
0.1–6553.5A
Depend on model
P02.11
Magnetic saturation coefficient 1 for  iron core of AM1
0.0–100.0%
80.0%
P02.12
Magnetic saturation coefficient 2 for iron core   of AM1
0.0–100.0%
68.0%
P02.13
Magnetic saturation coefficient 3 for iron core   of AM1
0.0–100.0%
55.0%
P02.14
Magnetic saturation coefficient 4 for iron core   of AM1
0.0–100.0%
40.0%
P02.15
Rated power of SM 1
0.1–3000.0 kW
Set the parameters   of controlled SM.
In order to ensure   control performance, set the value of P02.15–P02.19 based on the nameplate   parameters of the motor.
In order to ensure   control performance, configure the motor based on the motor which matches   with the VFD. If the gap between motor power and the matching motor is too   large, the control performance of the VFD will be deteriorated greatly.
Note: P02.16–P02.19   can be initialized by resetting rated motor power P02.15.
Depend on model
P02.16
Rated frequency of SM 1
50.00 Hz
P02.17
Number of poles pairs for SM 1
1–128
P02.18
Rated voltage of SM 1
0–1200 V
Depend on model
P02.19
Rated current of SM 1
0.8–6000.0 A
Depend on model
P02.20
Stator resistor of SM 1
0.001–65.535 Ω
After motor   parameter autotuning finishes, the set value of P02.20–P02.22 will be updated   automatically. These parameters are the basic parameters for high performance   vector control, which will impact the control performance directly.
When P00.15=1 (rotary   autotuning), the set value of P02.23 can be updated automatically via   autotuning; when P00.15=2 (static autotuning), the set value of P02.23 cannot   be updated via autotuning, calculate the value of P02.23 and update it   manually.
Depend on model
P02.21
Direct axis inductance   of SM 1
0.01–6553.5 mH
Depend on model
P02.22
Quadrature axis   inductance of SM 1
0.01–655.35 mH
Depend on model
P02.23
Back EMF constant of SM 1
When P00.15=2, the set value of P02.23 cannot be updated by autotuning,   please count according to the following method.
The counter- electromotive   force constant can be counted according to the parameters on the name plate   of the motor. There are three ways to count:
1. If the name plate   designate the counter-electromotive force constant Ke, then:
E= (Ke*nN*2π)/   60
2. If the name plate   designate the counter-electromotive force constant E’ (V/1000r/min), then:
E=E’*nN/1000
3. If the name plate   does not designate the above parameters, then:
E=P/√3*I
In the above   formulas: nN is the rated rotation speed, P is the rated power and   I is the rated current.
Setting range: 0–10000
320
P02.24
Reserved
P02.25
Reserved
P02.26
Motor 1 overload protection
0: No protection
1: Common motor (with   low speed compensation). Because the heat-releasing effect of the common   motors will be weakened, the corresponding electric heat protection will be   adjusted properly. The low speed compensation characteristic mentioned here   means reducing the threshold of the overload protection of the motor whose   running frequency is below 30 Hz.
2: Variable   frequency motor (without low speed compensation) Because the heat-releasing   effect of the specific motors won’t be impacted by the rotation speed, it is   not necessary to adjust the protection value during low-speed running.
P02.27
coefficient
Motor overload   multiple M = Iout/(In × K)
In is the rated   current of the motor, Iout is the output current of the VFD and K is the   motor overload protection coefficient.
The smaller K is,   the greater M is, and the more likely protection is implemented.
When M=116%,   protection is performed after motor overload lasts for 1 hour; when M=150%,   protection is performed after motor overload lasts for 12 minutes; when   M=180%, protection is performed after motor overload lasts for 5 minutes;   when M=200%, protection is performed after motor overload lasts for 60   seconds; and when M≥   400%, protection is performed immediately.
Setting range: 20.0%–120.0%
100.0%
P02.28
Motor 1 power display correction coefficient
This function   code is used to adjust the power display value of motor 1 only.
Setting range: 0.00–3.00
1.00
P02.29
Parameter display of motor 1
0: Display according   to the motor type
1: Display all
