下拉刷新
The type designation contains VFD information. You can find the type designation on the type designation label attached to the VFD or the simple name plate.
Figure 2‑2 Type designation rules
Key | No. | Description | Remarks |
Abbreviation | ① | Product series abbreviation | GD300-29 is short for Goodrive300-29 |
Rated power | ② | Power range | 037: 37kW |
Overload capability | ③ | Overload capability | G: Heavy load type, 150% of the rated load can last 60s P: Light load type, 120% of the rated load can last 60s |
Voltage degree | ④ | Voltage degree | 4: AC 3PH 380V (-15%) -440V (+10%) |
Rectification and feedback method | ⑤ | Rectification and feedback method | I: IGBT high-frequency rectification, sine wave feedback D: Diode rectification, six-pulse feedback |
Management number | ⑥ | Industry oriented | S: Petrolium industry J: Construction machinery T: Common industries |
⑦ | Whether to include the feedback reactor as standard configuration | L: Include the feedback reactor as standard configuration Empty: Not include the feedback reactor (if required, the customer shall specify the requirement in the procurement order.) |
