下拉刷新
Function description | Specification | |
Power input | Input voltage (V) | AC 3PH 380V (-15%)–440V (+10%) |
Input current (A) | See "Product ratings". | |
Input frequency (Hz) | 50Hz or 60Hz, allowable range: 47–63Hz | |
Power output | Output voltage (V) | 0–Input voltage |
Output current (A) | See "Product ratings". | |
Output power (kW) | See "Product ratings". | |
Output frequency (Hz) | 0–400Hz | |
Technical control performance | Control mode | Space voltage vector control, sensorless vector control (SVC), and vector control with sensor feedback (FVC) |
Motor type | Asynchronous motor (AM) and permanent magnetic synchronous motor (SM) | |
Speed regulation ratio | For AM1: 1:200 (SVC); for SM1, 1:20 (SVC); 1:1000 (FVC) | |
Speed control precision | ± 0.2% (SVC); ± 0.02% (FVC) | |
Speed fluctuation | ± 0.3% (SVC) | |
Torque response | < 20ms (SVC); < 10ms (FVC) | |
Torque control precision | 10% (SVC); 5% (FVC) | |
Starting torque | For AMs: 0.25Hz/150% (SVC) For SMs: 2.5Hz/150% (SVC) 0Hz/200% (FVC) | |
Overload capacity | 150% for 1 minute (for the G type) ; 120% for 1 minute (for the P type) | |
Running control performance | Frequency setting method | Settings can be implemented through digital, analog, pulse frequency, multi-step speed running, simple PLC, PID communication, communication and so on. Settings can be combined and the setting channels can be switched. |
Automatic voltage regulation | The output voltage can be kept constant although the grid voltage changes. | |
Fault protection | More than 30 protection functions, such as protection against overcurrent, overvoltage, undervoltage, overtemperature, phase loss, and overload | |
Speed tracking restart | Used to implement impact-free smooth startup for rotating motors Note: The function is available only for 004G/5R5P and higher models. | |
Peripheral interface | Terminal analog input resolution | No more than 20mV |
Terminal digital input resolution | No more than 2ms | |
Analog input | 2 inputs; AI1: 0–10V/0–20mA; AI2: -10–10V | |
Analog output | 1 input; AO1: 0–10V/0–20mA | |
Digital input | Four regular inputs; max. frequency: 1kHz; internal impedance: 3.3kΩ Two high-speed inputs; max. frequency: 50kHz; supporting quadrature encoder input; with speed measurement function | |
Digital output | One high-speed pulse output; max. frequency: 50kHz One Y terminal open collector output | |
Relay output | Two programmable relay outputs RO1A: NO; RO1B: NC; RO1C: common RO2A: NO; RO2B: NC; RO2C: common Contact capacity: 3A/AC250V, 1A/DC30V | |
Extended interfaces | Three extended interfaces: SLOT1, SLOT2, and SLOT3 (control board of above 7.5kW) Supporting PG cards, programmable expansion cards, communication cards, I/O cards and so on | |
Other | Mounting method | Wall mounting, floor mounting, and flange mounting |
Temperature of running environment | -10 – +50°C; derating is required if the ambient temperature exceeds 40°C | |
Ingress protection rating | IP20 | |
Pollution degree | Degree 2 | |
Cooling method | Forced air cooling | |
Braking unit | The VFD models of 037G/045P and lower contain built-in braking units. The braking units are optional parts for the 045G/055P–055/075P VFD models, and the braking units can be built in or externally connected. | |
EMC filter | The transmission of the VFD meets the IEC/EN 61800-3 C3 requirements. When optional filters are connected externally, the transmission of the VFD can meet the IEC/EN 61800-3 C2 requirements. Note: Comply with the EMC requirements and the technical requirements for the motors and motor cables in the appendix in the manual. |
