Function    code
Default    value
Modify
P12.00
Motor type 2
0: Asynchronous   motor
1: Synchronous motor
Note: Switch the current motor by the switching channel of P08.31.
P12.01
Rated power of asynchronous motor 2
0.1–3000.0kW
Set the parameter of the controlled asynchronous motor.
In order to ensure the controlling performance, set the P12.01–P12.05 according to the name plate of the asynchronous motor.
Goodrive300 series VFDs provide the function of parameter autotuning.   Correct parameter autotuning comes from the correct setting of the motor name   plate.
In order to ensure the controlling performance, please configure the   motor according to the standard principles, if the gap between the motor and   the standard one is huge, the features of the VFD will decrease.
Note: Reset the rated power of the motor (P12.01), initialize   the motor parameter of P12.02–P12.05
Depend on model
P12.02
Rated frequency of asynchronous motor 2
0.01Hz–P00.03
(Max. frequency)
50.00
Hz
P12.03
Rated speed of asynchronous motor 2
1–36000rpm
Depend on model
P12.04
Rated voltage of asynchronous motor 2
0–1200V
Depend on model
P12.05
Rated current of asynchronous motor 2
0.8–6000.0A
Depend on model
P12.06
Stator resistor of asynchronous motor 2
0.001–65.535Ω
After finish the motor parameter autotuning, the set value of P12.06–P12.10   will renew automatically. These parameters are basic parameters controlled by   vectors which directly impact the features.
Note: Users cannot modify the parameters freely.
Depend on model
P12.07
Rotor resistor of asynchronous motor 2
0.001–65.535Ω
Depend on model
P12.08
Leakage inductance of asynchronous motor 2
0.1–655.35mH
Depend on model
P12.09
Mutual inductance of asynchronous motor 2
0.1–655.35mH
Depend on model
P12.10
Non-load current of asynchronous motor 2
0.1–6553.5A
Depend on model
P12.11
Magnetic saturation coefficient 1 for the   iron core of AM2
0.0–100.0%
80.0%
P12.12
Magnetic saturation coefficient 2 for the   iron core of AM2
0.0–100.0%
68.0%
P12.13
Magnetic saturation coefficient 3 for the   iron core of AM2
0.0–100.0%
57.0%
P12.14
Magnetic saturation coefficient 4 for the   iron core of AM2
0.0–100.0%
40.0%
P12.15
Rated power of synchronous motor 2
0.1–3000.0kW
In order to ensure the controlling performance, set the P12.151–P12.19 according to the name plate of the asynchronous motor.
Note: Reset the rated power of the   motor(P12.15),initialize the motor parameter of P12.16– P12.19.
Depend on model
P12.16
Rated frequency of synchronous motor 2
0.01Hz–P00.03
(Max. frequency)
50.00
Hz
P12.17
Number of poles pairs for synchronous motor   2
1–50
P12.18
Rated voltage of synchronous motor 2
0–1200V
Depend on model
P12.19
Rated current of synchronous motor 2
0.8–6000.0A
Depend on model
P12.20
Stator resistor of synchronous motor 2
0.001–65.535Ω
Depend on model
P12.21
Direct axis inductance of synchronous motor   2
0.01–655.35mH
After finish the motor parameter autotuning, the set value of P12.20–P12.22   will renew automatically. These parameters are basic parameters controlled by   vectors which directly impact the features.
When P00.15=1, the set value of P12.23 can be updated through   autotuning automatically, and there is no need to change the value of P12.23;   when P00.15=2, the set value of P12.23 cannot be updated through autotuning,   please account and update the value of P12.23.
Note:Users cannot modify the parameters freely.
Depend on model
P12.22
Quadrature axis inductance of synchronous   motor 2
0.01–655.35mH
Depend on model
P12.23
Back EMF constant of synchronous motor 2
When P00.15=2, the set value of P12.23 cannot be   updated by autotuning, please count according to the following method.
The   counter-electromotive force constant can be counted according to the   parameters on the name plate of the motor. There are three ways to count:
1. If the   name plate designate the counter-electromotive force constant Ke, then:
E=(Ke×nN×2π)/ 60
2. If the   name plate designate the counter-electromotive force constant   E’(V/1000r/min), then:
E=E’×nN/1000
3. Iif   the name plate does not designate the above parameters, then:
E=P/√3×I
In the   above formulas: nN is the rated rotation speed, P is the rated   power and I is the rated current.
Setting   range: 0–10000
300
P12.24
Initial pole position of synchronous motor   2 (reserved)
0–FFFFH (reserved)
0x0000
P12.25
Identification current of synchronous motor   2 (reserved)
0%–50%(the rated   current of the motor) (reserved)
10%
P12.26
Motor 2 overload protection
0: No protection
1: Common motor(with low speed compensation)
2: Variable frequency motor (without low speed compensation)
P12.27
coefficient
Times of motor overload   M = Iout/(In×K)
In is the rated   current of the motor, Iout is the output current of the VFD and K is the   motor protection coefficient.
The smaller K is,   the greater M is, and the more likely protection is implemented.
When M=116%,   protection is performed after motor overload lasts for 1 hour; when M=150%,   protection is performed after motor overload lasts for 12 minutes; when   M=180%, protection is performed after motor overload lasts for 5 minutes;   when M=200%, protection is performed after motor overload lasts for 60 seconds; and when M≥ 400%, protection is performed immediately.
Setting range: 20.0%–120.0%
100.0%
P12.28
Correction coefficient of motor 2 power
Correct the power   displaying of motor 2.
Only impact the displaying   value other than the control performance of the VFD.
Setting range: 0.00–3.00
1.00
P12.29
Parameter display of motor 2
0: Display according to the motor type: only the parameters corresponding   to the current motor type are displayed for the convenient for the customers   in this mode.
1: All parameters are displayed: all parameters are displayed in this   mode.
